Standard key registration is required when a standard key is lost and needs to be replaced, or when
the code re-registering key is re-registered after the immobilizer unit or ECU are replaced.
NOTE:
Do not start the engine with a standard key that has not been registered. If the main switch is turned
“ON” with a standard key that has not been registered, the immobilizer system indicator light flashes
to indicate fault code “52”. (Refer to "SELF-DIAGNOSIS FAULT CODE INDICATION" on page 8-67).
1. Check that the immobilizer system indicator light signals the standby mode.
2. Using the code re-registering key, turn the main switch to “ON”, then “OFF”, and then remove the
key within 5 seconds.
3. Insert the first standard key to be registered into the main switch, then turn the key to “ON” within
5 seconds to activate the key registration mode.
NOTE:
The existing standard key code is erased from the memory when the key registration mode is activated.
When the key registration mode is activated, the immobilizer system indicator light flashes
rapidly.
4. While the indicator light is flashing, turn the main switch to “OFF”, remove the key, and within 5
seconds, insert the second standard key to be registered into the main switch.
NOTE:
If he immobilizer system indicator light stops flashing 5 seconds after the first standard key is registered,
the registration mode is deactivated. If this occurs, the second standard key cannot be registered,
and steps 2 to 4 need to be repeated to register both standard keys.
5. Turn the main switch to “ON”.
NOTE:
When the indicator light goes off, the registration is complete.
6. Check that the engine can be started with the two registered standard keys.
Thought I'd add this too as it may be useful for anyone who looses a standard key...
Voiding the standard key code: If a standard key has been lost, it is possible to disable its use by re-registering the remaining standard key. Standard key registration erases the stored standard key code from the memory, thus disabling the lost standard key.To re-register, refer to “Standard key registration”. Standard key code voiding method a. Main switch “ON” b. Main switch “OFF” c. LED on d. LED off e. Less than 5.0 s f. Code re-registering key g. Remaining standard key h. Registration mode A. If the immobilizer system indicator light stops flashing 5 seconds after the first standard key is registered, the second standard
