wired_af
It's the chain. Tighten it the noise will get worse. Loosen it the noise will go away. If its within spec and your sure your checking the slack property I wouldn't worry about it.
It's the chain. Tighten it the noise will get worse. Loosen it the noise will go away. If its within spec and you're sure you're checking the slack properly I wouldn't worry about it.
Its a bit agricultural isn't it. I hate the massive clunk when selecting first for the first ride of the day. On the plus side I have been impressed with the quality of the chain and spockets. My previous bike needed nearly weelkly adjustments.I returned my '05 FZ6 to my dealer when I first heard the whine after the first time my chain was adjusted, only to be told it's nothing to worry about and normal.
My new '07 has exactly the same noise.
The FZ6 is perfect is so many ways, but I'm sure lots of us agree the transmission needs some attention in the next generation.
