hobo7
I'll address the elephant in the room first. Yes, I know I'm an idiot.
With that said, made a Chipotle run, came back, pulled into my garage, hit the kill switch and went to go eat. When I went to get my keys to leave later, I realized I had left my key in my bike and it was still switched to "ON" for about 4ish hours.
Figured no biggie, I'd get that trickle charger I needed anyway for winter, and let my battery charge outside the bike. Battery went to full, so I reinstalled it, and switched it back to "ON".
My issues are the following: Instrument cluster doesn't turn on at all. I checked all fuses, and none looked blown. It keeps making a steady clicking sound while the engine cut-off switch isn't set, and when I attempt to use the starter, it seems to be attempting to start, but no dice.
All of the above is documented in my short video. I also point to whatever it is making the noise. Ignore the air freshener, it was just to keep my front fairings from getting smashed by my fuel tank
[ame=http://www.youtube.com/watch?v=dJtz4C67pUE]FZ6 won't start - left ignition on for ~4 hours. - YouTube[/ame]
I just hooked the bike up to my charger and will leave it charging all night to see if that makes any difference, but I'm suspecting I foo-barred my battery.
Side note: The bike was hooked up to the charger while doing these tests, if that makes any difference.
Any advice would be appreciated. Thanks!
