Led turn signal install-flasher relay
koolcat
Tx
Picked up a cheap set of led signals for the front and made the necessary connections , but the flash rate has sped up now for the front and back..(which I did not replace).. so I've dug around on the forum and there's lots if ideas.. Basically I need a different relay but I'm wondering if anybody has found the appropriate replacement relay at autozone ..and knows the part number?
kyle
Bristol, TN
Just to confirm, a single relay is all that's needed for both front and back signals, correct? I just order a couple sets and a relay to replace the stock gargantuan signals in front and the invisible smoked incandescent ones Mr. Previous owner put on the back. Figured I'd add to the farkling I'm doing when my top case arrives.
