cmantis
I had posted in another thread that I went down. Now I need to get her all healed up. When I went down it was on the right side and the frame slider took most of the abuse. Three things though need attention:
1) I leaked out some coolant and now she is running hot. Am I ok to just replace some into the reservoir or do I need to flush and refill again?
I recently replaced the coolant and while I can't remember the exact brand was 50/50 which I have more of in a new bottle (perhaps different brand) at home.
2) The front fairing on the right side ended up with a small crack on the top like behind the mirror (only about 1") as well as the tab where the bolt holds it to the stay above the headlight rubber boot broke (so it is kind of hanging). How can I repair this is there some sort of glue that will bond ABS(?) plastic?
3) The entire front end plastics (not frame or forks) is slightly shifted up and to the left (fell on the right). It isn't that noticeable except to me sitting on the bike and where you look at the gaps between the plastics and the gas tank or frame but it is rubbing on the tank taking the paint off. Is it possible to bend it back or order just new stays and replace those?
* The most critical at the moment is dealing with the over heating so I can get to and from work.
Thanks in advance!
Thanks in advance!
