has anyoned used this?
Oblinox
Richmond Va
i am in the need for some chain lube and heard good things about bel ray
i was browsing amazon and found this wanted to see if anyone has used it on here?
[ame=http://www.amazon.com/BEL-RAY-CHAIN-LUBE-EACH-92400-A16/dp/B0012TSRKI/ref=sr_1_1?ie=UTF8&s=automotive&qid=1245782690&sr=8-1]Amazon.com: BEL-RAY CHAIN LUBE 16 OZ. EACH 92400-A16: Automotive[/ame]
I used the BelRay on my Bandit and it good stuff, not great. It's important to find a balance between getting enough to keep the chain lubed and not getting too much. It will sling all over if you use too much. Like most chain lubes, it can be a pain to clean up. After seeing good results on a friend's SV1000, I am switching to the Dupont for the chain on the FZ. Had I not discovered the Dupont, I would be using the BelRay on the FZ too.
