FZ6 Headlight
Pedro Vinicius
Brazil
Hello! I bought the headlight parts from the FZ6-N to put on the FZ6-S. I have a question about how to connect this secondary lamp that is on the top of the headlight. Could anyone help me?A.webpB.webp
Welcome to this great forum Pedro!
The wire that runs the low beam on your H4 headlamp wi;; bee fine to use, Than't the black wire with the green tracer.
You should also be able to use one of the wires from the directional harness on the left or right side of the bike. The color code for those wires is blue on one side of the bike and blue with a red tracer on the other side. Then you will provide the ground.
Bem-vindo a este grande fórum Pedro!
O fio que conduz o farol baixo do seu farol H4 será bom de usar, assim como o fio preto com o traçador verde.
Você também deve conseguir usar um dos fios do chicote direcional no lado esquerdo ou direito da bicicleta. O código de cores para esses fios é azul em um lado da bicicleta e azul com um traçador vermelho no outro lado. Então você fornecerá o aterramento.
Thanks for the welcome. Would you have any images? I didn't understand very well
Here is an example of the headlamp plug that would plug into your original headlamp plug. If your head light plug has 3 wires yo could use the low beam and ground on your original wiring to additionally power your upper running lamp. There are running lamp wires in the directional light harness at the front of the bike that can also be used.
See this link: https://www.600riders.com/threads/turn-signal-help.60442/
