ghugenberg
I recently bought a 2005 fz6. The previous owner liked to work on it but didn't know what he was doing. I have fixed most of his botched mods except the clutch. It shifted very rough but smoothed out when I tightened the clutch cable except the clutch would not fully engage. I looked at the little lever on the crank case. It appeared to be lengthened. (not an un-common practice) I drilled a new pin hole and shortened the arm. The bike wouldn't start when in gear with the clutch in and stalled when putting it in gear. I screwed arround moving the arm on the shaft and got it working way better than before but it still was a little rough. I was too stupid to leave well enough alone. I drilled another hole and moved the pivot pin in farther. I marked exactly how it was so I could put it back if there was a problem. Now the bike stalls when I put it in gear and will not start while in gear with the clutch in. I have adjusted it a hundred different ways including back to the way it was. Is there some trick? I'd take it to the dealer but I can't drive it. Please help.
Thanks,
Greg
[email protected]
Thanks,
Greg
[email protected]
