- Joined
- Apr 6, 2009
- Messages
- 1,318
- Reaction score
- 44
- Points
- 0
- Location
- pittsboro, nc (near raleigh)
hey guys,
i have a few electrical questions. i got to thinking that i have a number of things hooked up to my battery right now.
- +/- from HID projectors
- battery tender plug
- gerbing plug (from previous owner but i hopes of using it one day
- grip warmers
- planning on getting a stebel nautilus
i'm wondering if it isn't just time to wire up a fuse block. i figure i'd leave the battery tender plug hooked directly to the battery but move everything else to the fuse block.
the local auto store has one of these (ebay link for pictures sake)
it is rated at 30 amps. i'm assuming that'll be fine. i'm also assuming i'll need one of these to run my grounds to.
i have done some research but i'd like to make sure i have everything straight before i go off and buy the parts.
1 - almost everything is showing that i will need a relay between the battery and the fuse block. is a 30A relay enough?
2 - do i need to put a fuse between the battery and the relay? i wouldn't think so but i wanted to check and make sure.
3 - since i will be putting this either under the tank or under my seat should i run 12awg wire since it will be longer wire runs?
4 - i had planned on using a relay to hook up my hand warmers. but if this fuse block will have a relay on it to keep it from getting power unless the key is on i would think i shouldn't have to run a relay for the hand warmers now.
trust me, there will be more questions to follow, but i'll stop here for now. thanks.
- grip warmers
