fastar1
Oh the irony.You simply do not understand what you are talking about.
They quite simply are NOT proportional in any way. I have explained this and I have illustrated this and it is obvious that I cannot get you to understand it, but at least now we know the source of our disagreement. I'm happy to let forum readers decide for themselves whatever makes most sense from the information we provided.These are the things you need to get in your head.
* Every engine is different and has a best RPM to run at. Above or below to optimum RPM is a decrease in fuel efficiency/power efficiency. The optimum RPM of an engine can be low, mid-range or high depending on how it is built.
* Fuel efficiency is directly proportional to power efficiency. This should be obvious even to those with no knowledge of physics or chemistry. What is powering your engine? Gas of course. Power is the rate of which energy is released, gas is stored chemical energy.
Priceless.What would this look like riding?
You would accelerate at fast as possible to your engines optimum RPM, not exceeding your limiting velocity(probable 60 mph).
Then you would pull in the clutch, close the throttle, and coast.
After bike drops to your lower velocity limit, RPM match your speed, release the clutch and accelerate as fast as you can to your upper limit... repeat the process over and over.
That is how you would get the max Miles per gallon.
