Complete LED Kit
mdfb42
618 (IL)
Since switching to a Vmax I have extra parts that I won't be needing any longer.
I just recently purchased some Yamaha OEM LED turn signals, NIB Motodynamic Clear Sequential Tail light, and Flash Regulator (this way you don't have to mess with any resistors).
I'm just trying to get close to what I had in them and send them to a good home.
Asking $200 shipped in to any of the 48 states.
Can post/send pics if needed.
Hi. I'm glad to know that your using this kind of kit. :)
Nice so that one relay is good for all four signals? Do you have and idea of how much total wattage I will save with this led setup versus stock?
Last one, is the Motivational tail light smoked or clear?
Thank you.
Yes. The regulator replaces the need to use resistors at each turn signal
No clue on the wattage. The electrical gurus in the electrical section may know that one.
The motodynamic is clear to match the turn signals
Edit: here's how easy the flash regulator is compared to soldering resistors on
http://youtu.be/7mwW4zE0dCw
Great.
The one relay shown works with all lights, or are there one for each?
All lights
If you used resistors, you would need for all lights, but the relay just reduces the standard flash rate and therefore with the lower load the LEDs use, it creates a regular flash rate instead of a fast flash rate
Thank you. I'm really considering it. I hate to sit on it for a few.
Thank you.
Take your time. No hurry. Not like they take up a whole lot of space at the house. Let me know when you decide either way. Until then, ride it like you stole it! :rockon:
Those that want all together get first dibs. If I find a person for the turn signals and one for the taillight, then I will be willing to separate
Ok, fair enough. I've already got the flasher and a certain set of LED signals in mind that I want to buy. I'm just interested in the motodynamic tail light. [emoji3] Keep me posted.
