See
Yamaha Fazer FZ6 S2 2007 Service Manual ENG for diagram
1. Remove windshield - 6 plastic screws
2. Remove 2 screws each side of main fairing (labeled as 5Nm torque in diagram). They also secure item #1.
2a. Remove item #1 both sides.
3. Remove item #5 - 4 screws
4. Remove mirrors - 4 nuts
5. Unscrew front indicator brackets (#3) - 2 screws each side
5a. unplug the connectors to the headlamp bulbs.
5b. Pull out the side lights.
6. Unplug 2 electrical connectors in near/side of fairing and roughly above n/s front indicator bracket
7. 3 screws remain which secure the front fairing #4 to the headlamp assembly. Undo these and standing at the front of bike pull the main fairing towards you.
You now have access to the instrument unit which is screwed to the framework with 3 screws.
Undo these and you can lift the instrument unit and other wires.
You should be able to strip the front down in half an hour.
I did it last weekend. I dropped my bike and had to straighten the frame which supports the front headlight assembly and fairing.
Top tip - cover your front mudguard as you will drop nuts, screws and hex keys onto it. Cover your tank also particularly when removing item #1.
Good luck.
