Texas7t
I turn the key on and all lights go on, but when I push the button to start it then all I get is. " click click click click click ..
I read how a battery charger can do more damage then good.. True for a car charger.. but I did have a small amp charger for bikes,. I hooked up the cables and set it to low charge and 12v, and let it charge over night. The next day, it had power for the bike, but not enough to start, I set the bike and first gear and pushed it, and it started.. tossed on my gear and went for a 30 min ride toe get the juice going.
I got back to my garage, and turned off the bike and let it sit a few.. then tried it again.. and she started right up.. I've been gone for three days now, and will see if she still starts up.
Yes a battery charger can ruin a good battey if left on too long but the battery tender he is refering to cant mess up a battery I dont knoe exactly how it works but basicly it knows when the battery is full so it wont overcharge it
Sent from my R800x using Tapatalk
This is a classic example of a low battery. Not enough juice in there, to turn the starter motor. The solenoid is repeatedly trying to engage the starter motor. Whenever the motor tries to move it sucks up ALL of the available electricity.
You should still have enough energy in the battery to start the bike, but not with the button.
Put the bike in third gear. Turn on the ignition and let the fuel pump pressurize the system. You'll hear the whine stop.
Once that's done, pull in the clutch, and get the bike rolling pretty quickly. Hop on, pop the clutch out, and let the rear wheel spin the engine. It should start; at which point you need to pull in the clutch so you don't stall. Put the bike in neutral, stop, put on your gear, and then go for a ride for at least 15-20 minutes. Keep the engine RPM above 1500 as much of that time as you can so the alternator can produce enough extra juice to replenish the charge in the battery.
