Broke clutch level sensor pin
n0other
biker wannabe
Lithuania
While fitting the2wheels levers I accidentally broke the pin of the clutch lever sensor, should I be worried or the only downside will be not being able to start in gear + clutch (a bad habit to have anyway IMO)? I assume that's the only thing this is there for.
EDIT: Okay, it starts in gear just fine, what's it for?
EDIT2: it's there to prevent from starting in gear without the clutch pulled in, having the pin broken is the same as having the pin fully out all the times = clutch pulled in so right now I'd be able to start in gear without pulling in the clutch and that's the only downside.
