Anybody drilled their stock exaust?
goran21220
memphis
I've read all threads about the subject but nobody actually commented about how it sounded after(maybe one member...). I'm thinking about doing it since i can't afford new pipes.Few smaller holes or one bigger one? I just want it to be a little louder.Anybody who have done it already?
[ame="http://uk.youtube.com/watch?v=rclSypU5rw8&feature=related"]YouTube - 2005 fz6 stock exhaust drilled.[/ame]
I'm fairly sure I posted this before, not the best sound clip, but should give you some idea...;)
Kinda sounds like a pissed off chainsaw in a way...
I did it before I got my new exhaust and drilled in each hole. I used a 1/2 inch masonry bit for mine. After i was done, the bit was destroyed, literally. :D Make sure you use a masonry bit, unless someone suggests something different that works better, because it's hard metal in there. Good luck and when I did it, it sounded just like the vid above.
+1 A pissed off chainsaw is right on the nose! :thumbup:
Ther are pictures and coments on this many times in many threads, ive got pictures on here and 7 days ago did a big write up on another thread of the same. Do some search's and you should be able to see what everone has done and said.:thumbup:
Sounds kind of like a 2 stroke weed whacker to me. Personally I prefer the stock (quiet) sound. I use a Scala rider Q2 to listen to music while I ride. The speakers aren't terribly load so a louder exhaust would probably drown out the tunes.
If you do decide to drill it a regular drill bit will work you just have to know how to drill stainless steel...low speed medium pressure. If you go at it high speed and a lot of pressure it builds to much heat and ruins the bit as well as making what your trying to drill harder. No need to waste a good masonary bit on metal
