Z
Zealadin
Just also remember pulling in your clutch before you brake, basically frees up your momentum, so you want to be braking while you pull it in, without grabbing a handful.
Too much rear brake and the wheel locks up EASILY same as downshifting when your moving too fast without the clutch all the way in.
Too much weight into the front brake suddenly and you will lock it up too, and if its wet/slippery its NOT FUN! Learnt this from personal experience on a semi new tyre.
Normally you want 70/30 front/rear brake for safe stopping, using only one or the other in a situation can lead to seriously problems/injury.
If you lock up your back wheel don't stress, if your pulling up on a straight line and hold your balance you just need to release it and put the pressure back on a bit lighter (don't release the clutch while doing this tho)
There are not many situations where I actively -use- engine braking because unless its used in conjunction with your brakes, you aren't displaying a brake light which is dangerous. You might stop in time but the driver behind you in his 4x4 will just run straight over you without realising because his driving skills are about equal to his taste in vehicles.
All in all as you ride more you will automatically remember to shift down, its just part of braking, and if you don't have time to do it in an emergency then you should still be aware what gear you are in, and whether there may be a threat from other vehicles not stopping in time behind you.
