Air pump hose
Have you ever changed the plugs on a FZ6???
I bought a small cheap (under $15)12v air comp. and a plug to match the battery tender plug. Cut off the plug on the air comp. and replaced with new plug. Now all I do is carry the small air comp with a goo string kit and I am good to go for less than $25.
WAY easier than trying to plug into the spark plug (try that in the dark while raining).
I do know this works as I have the same setup on my KLR and had to use it for a slow leak when out in the woods last week.
That plug worked on a tubed tire???
+1 on just getting a small 12 volt air pump and plugging in....
