Freak
Has anyone ever advanced the timing on a FZ6. Im assuming its quite retarded to have 12.1-1 compression and be able to run on standard 87-91 octance fuel. Could be some power gains there if there were a way to advance it.
Probably is a way to cause a timing advance. I read an article on a little gadget that was plugged into the harness on a Kawi ZX14 and it fooled the computer onto thinking it was in 6th gear where the timing would get advanced, as apposed to the first 5 gears which where retarded. It worked great and they really decreased their times in the 1/4 mile. The only downfall was it messed with the gear indicator which always thought it was in 6th gear.
Very worth researching!:rockon:
Cliff
that would be a TRE or timing retard eliminator
doubt they make one for our bike
as have seen them for mainly Suzuki
It would be fairly easy to make a new trigger wheel with an offset on all the teeth. That would do the job. But then you'd be stuck running premium.
You might gain a few HP. IMHO, not worth it, but others may disagree.
I don't see any reason why it would not work.
Fred
Is this part of Yamaha's "detuning" of the R6 motor?
I have been lucky enough to get high octane from a single source for 4 years, except on long trips anyway, no way to carry extra fuel on a street bike.
I would be very interested in knowing more if you guys are doing the research and feel like sharing it.
I am a backyard mech so I am not as savvy as freak.
