06 FZ6 Parts
Crashz28
Houston
Ok all these parts are from a 06 FZ6 with around 12k miles and are in good working condition the only reason I am selling them is I changed them out with R6 parts I will also have some internal motor parts once I strip down the original motor and figure out what broke!
FZ6 wiring harness complete missing one brake light connector- $50
FZ6 ECU - $60
FZ6 Headlight harness missing the headlight plugs- $10
Fz6 Starter motor-$100
FZ6 ignition coils- $50
FZ6 Throttle bodies missing the intake air pressure sensor-$75
FZ6 Stator $50
FZ6 stator cover $40
FZ6 timing cover and timing pickup- $20
FZ6 Fuel Pump-$40
I think its 6 or 8 allen head bolts to remove the pump runs perfect I only swapped it out for the r6 pump becuase I swapped in the R6 fuel rail and I needed the return port on the R6 pump! The pump has around 12k miles on it!
Pump takes about 20mins to remove from the tank after you have the tank off!
I will check on shipping for you tomorrow!
