StreetGrim
Starter motor is good and spins strong on bench.
Engine rotates freely by hand.
Tried jumping with a car battery and still same issue.
With the idler gear removed, the starter spins fine when bypassing the solenoid.
When the idler gear is installed, the system locks up, the starter won’t turn the engine and all electrical power drops (lights shut off when trying to crank).
Starter clutch appears to free spin one direction and lock the other as expected when tested by hand.
Bike sat over winter before this issue started.
Trying to determine if this is a stuck/binding starter clutch under load?
Any input appreciated.
