Abiram Menon
@Motogiro and @TownsendsFJR1300 Please Help. I'm dealing with a rather complex issue here. I entrusted my decently reputed garage to change my spark plugs, and they asked me permission to clean the throttle body. They cleaned and damaged the O-rings! Now, I'm dealing with all kinds of idling and vacuum sync issues (V-twin sound beat included). The sync imbalance is causing the infamous resonance at 5k to 7k rpm. They managed to replace the O-rings with some similar size and got back the idling and the vacuum sync on the 5th attempt. But now, i have a snatchy throttle (sudden surge of power in small openings). They mentioned that there's some leak, have corrected up to 90% and cannot do 100% vacuum sync coz of this. Should I specifically order some OEM O-rings if they are available? Also, to my horror, I found out that half of the airbox screws have lost thread. Will this create any other issues? Somehow the remaining three screws are tight enough. I am trying to find the source of minor vibrations further. Is there any other direction towards what all are to be checked for vibrations?
1) There's a noticeable resonance coming from under the seat/subframe
2) Exhaust headers are never checked. Shall I?
3) Rev and touch the cylinder head (Cold); I can feel it's silken smooth. But there's a Givi crash guard which, if I hold, will vibrate our whole body (One mount connected to the engine mount)
4) Spark plug caps?
5) Valve Clearance?
6) Checking all fairing mounts and screws? Torque check?
4) Spark plug caps?
5) Valve Clearance?
