Buy OEM Parts for Yamaha, Motorcycle, 1991, FZR600RB
www.partzilla.com
I don't see a tip over switch so that's not an issue..
Couple things to check and give a definite answer:
-Make sure battery is fully charged, perhaps
"load test" as well. You need full voltage
for the engine to run. Plz post what the voltage of the battery is as of now..
-If the battery is fully charged and the engine cranks/spins over properly, pull the spark plugs, ground to the head and crank over. Ascertain you DO have a good spark for all cylinders-Post back the results...
-Should you have a good battery (passed load test) and good spark, spritz some fuel thru the air filter box (filter removed) and see if she fires off.
-It does have a
fuel pump (part #47):
https://www.partzilla.com/catalog/yamaha/motorcycle/1991/fzr600rb/fuel-tank
You need to ascertain that both the fuel tank valve DOES ALLOW FUEL to flow (IE, attach another test hose to valve), turn on and
see if fuel actually leaves the valve /tank.
-Back to the fuel pump, . Should you have fuel flow from the tank valve check to see if the fuel pump is indeed working. You can remove it, apply 12 volts to it with a test hose hooked up to to it sucking from a liquid supply (obviously if using gas, be careful) .
-Carbs. Part #25(pictured below) is the DRAIN PLUG/screw. When removed, fuel should empty from the carburetor(s). Ascertain fuel is indeed getting there and comes out when the drain screw is opened(CC)..
That should get you headed in the right direction..
*I'd be leaning towards it being a fueling issue, valve/pump, possible carbs just due to age crappy fuel now-a-days..
