For JesseeS,
Re stalling, idle, etc. As posted above, it shouldn't stall if the idle is set correctly. I can, on flat ground, idle set at 1,100, let the clutch out very slowly and the bike will go (NO throttle) and idle down the road(with my 200 lbs on it) without a problem..
Some have posted not to lug it, which I agree.
I can say, I can cruise at 2500 RPM, in 6th gear, open the throttle and it will pull, very smoothly, no knocking, pinging, etc. I don't do this often, (late at night in a reidential zone, keping the noise down from my aftermarket pipes.
At 4K RPM's is 48 actual MPH (6th gear). The city I live in, that speed is about average and the majority of the time, I'm running at 4k. Nailing the thottle at that RPM, the bike will pull very strongly (obviously NOT as strong as if at 8k) but plenty to get ahead of cage traffic.
The bike does need to be fully maintained, good plugs, a very accurate throttle sync, chan mainatained, etc..
