Hi Guys, I know this will be a repeated question, but, what should I choose according to my weather, usage and also, what amount of coolant should I buy?
I live in Charlotte, NC. Very rare track days, 60% city commute and interstates for the weekends.
The climate here is good, not too hot so far, but probably snows less than 10-15 times per year.
And how much quantity do I need to buy? how many gallons (probably a dumb question for most of you)?
I don't want to buy pre-mixes, as I don't want to pay for water, So, I want to mix it myself, So planning to buy
"aluminum-compatible ethylene glycol".
What is my suggested ratio based on above details?
In my apartment complex, there is a place where we can wash our cars and bikes with water hose. Can I drain this coolant there before having my weekly wash for the bike? Or should I compulsorily take it to the nearest recycling facilities?
And btw, can I use the same water in the mix, incase if I'm suggested to use water or I should use distilled water only?
Update:
About using water wetter as anti freeze. I would suggest using distilled water from a store rather than tap water. Your tap water might contain iron or other minerals that could oxidize inside the cooling system. Besides distilled water is only 68 cents for a gallon at walmart.
How to change coolant - Sportbikes.net
