Scott - I may hit you up with questions. I have been a little freaked out about changing the chain. having a continous chain with no link solves that problem.
weird though. I keep inspecting looking for defects but the original chain and rear sprocket both still look excellent at 32k miles. (front sprocket changed out already to 15t)
When I replaced mine, I bought a $90 tool and went with the DID X chain.
With that said, the stock, continous, Yamaha chain IS A
GREAT CHAIN, your mileage/maintainance proves it..
IMHO, as posted above, especially for commuting, I'd stick with the size sized chain/sprockets(530). Also, you probably know, the stock, front Yamaha sprocket has what appears to be a plastic ring which,
I think, helps with noise from under the cover..
I would steer clear of ANY aluminum sprockets as they'll wear much faster than steel..
*Another poster swapped his with a new YAMAHA continuous chain.
The Yamaha shop manual has you pulling exhaust off and all kinds of parts including shocks, suspension parts, etc.
The poster (forgot who it was), pretty much just
pulled the main, front swingarm bolt (left the exhaust alone), probably pulled the rear wheel for access (and less weight to deal with besides some room to work).
He was able to finagle the swing arm back just enough (on the left), remove the old chain out and sneak the new one in. It wasn't that big an issue.:thumbup:
