Your paddock stands are fine as welll as the install..
IMHO, I would put a small sizzor jack with a small piece of plywood or 2x4 under the header instead of the ft lift. Its a bit more stable should someone bump into the bike by accident... Either way is fine...
Re your battery and
cold temperatures, exactly
how cold (in
F if you could) can it get down to where's its stored???
From
Yuasa's site, some interseting reading:
Battery storage tips:
Yuasa Batteries - Storage & Spring Startup
FAQ's
Yuasa Batteries - FAQ's
Also, from their site:
Freezing: It shouldn’t bother you – unless a battery is
inadequately charged. Looking one more time at the
discharge process, remember that electrolyte acid becomes
water as discharge occurs. Now, it takes Arctic temperatures
to freeze acid. But water... as we all know, freezing starts
at 32°F. A sign of this is mossing – little red lines on the
plates. Freezing can also crack the case and buckle the
plates, which means the battery is permanently damaged.
A fully-charged battery can be stored at subfreezing
temperatures with no damage. As the
chart at right shows, it takes -75°F to freeze electrolyte in
a charged battery. But at just a couple degrees below
freezing – at +27°F – a discharged battery’s electrolyte
turns to ice. That’s a difference of more than 100°F
between the low temperatures a charged and discharged
battery can stand.
Electrolyte Freezing Points
Specific Gravity
of Electrolyte Freezing Point
1.265 -75°F
1.225 -35°F
1.200 -17°F
1.150 + 5°F
1.100 +18°F
1.050 +27°F
23
At temperatures such as these, incidentally, the self discharge
rate of a battery is so low that a recharge
usually isn’t needed for months. But to stay on the safe
side, test.
SECTION
Maintenance
and Storage
