Jon_PDX
Hi,
Not sure if I got the subject correct (could not decide how to write it) but hopefully I got close.
Anyway, I recently picked up a used 2007 FZ6 with 34K miles on the clock. While going over the bike I noticed that the chain is not centered over the rear sprocket. I checked alignment and it looks good but the chain rides to the outside of the sprocket. The chain is centered over the front sprocket.
Hope that made sense ???
So I pulled the rear wheel and the first thing I noticed is the last person to have the wheel off must have also moved the bracket that the rear caliper bolts to because it was on top of the raised area on the swing arm that the bracket would normally slide over.
That has now been corrected.
After putting it all back together and realigning the rear wheel the chain is still riding to the outside of the rear sprocket.
The only thing I can think of was maybe the spacers (collars) may be different widths on each side but I forgot to check them before putting the wheel back on. According to the parts fiche the collars (#19) are the same part number which would imply they should be the same width.
It's not off by much. Maybe a 32nd of an inch but has caused some wear on the inside (tire side) of the rear sprocket since the chain is rubbing on that side of the sprocket.
So if possible I'd like to correct it before I put a new chain and sprockets on the bike.
Any thoughts ???
Thanks,
Jon...
Any thoughts ???
Thanks,
Jon...
