Well my rear tire has no tread left on my pr3 the front is cupping badly with Higher tread in the center so I'm assuming slight over inflation and bad shocks
I believe I got 13k miles on the rear wheel
And 11.5k on the front
Time to replace them..... I contacted Michelin to ask what they suggest for psi try seed refer to manufacturer ok so 33-front 36 rear
I was running the high end of the specs 36 front 40 rear as I'm a bit heavier but I'm going to bring it down to the low end with this set of tires
My real questions are
1. Static or dynamic balance which is required for motorcycles as I'd prefer dynamic but is it actually done?
2. Valve stems I have now pitches the 90 degree billet ones as it would be nice to never replace again and be able to fill up and check psi easier
3 for balancing should I get the balancing beads I have heard they are much better
Any one suggestions or tips would be nice as I want these tires to wear better than my old ones
