I have to look into that. I have had the bike 11 months and i havnt changed the coolant yet. Is it not possible that because this is a naked bike, the air could be cold enough to whisk heat away that quickly?
The radiator is in the same place as a faired version, that alone wouldn't make a difference.
The thermostat is designed to
stay closed until the
water temp in the engine reaches 160F (I'd give or take a couple of degree's). With 25F outside (plus wind chill, especially while under way), the thermostat should be partially closing to keep the temperature of the engine to at least 160F.
Over cooling", page 9-3 in the 07 Yamaha shop manual quote "Thermostat" *thermostat stays open.
You should be able to start the bike cold as usual, just let it idle and watch the temp gauge rise steadily until 160F. Depending on your climate, I would think 10 minutes idleing would bring it up to full temp.
If the temp gauge stays low and never climbs, it re-inforces that the thermostat is likely open letting the coolant flow to the radiator, thus never heating the coolant fully.
Unfortunatly, the thermostat is located below the throttle bodies at the rear of the engine cylinder. The manual calls for removing the TB's (and everything else before that). You can see a large coolant hose wrap around the left side of the bike to the rear of the cylinder. The thermostat is under the housing (two bolts hold the housing) that hose connects to. I've never had to change the thermostat out on the FZ6, you can see the bolts but its super tight with the TB's in place..
I'll send you a PM...
