WTB Tank bolts
dpaul007
Lake Crystal, MN
Had 1 bolt that fell out that secures the front of the tank to the frame. If anyone is doing a part out or has ordered extra of these, I'm looking for 1.
Part # 90110-06079-00
Smaller hardware stores like Ace or True Value usually have a good selection of metric stuff, and they sell them individually. I don't even bother looking Home Depot or Lowes for metric nuts-n-bolts.
If all else fails, you can go to bikebandit.com
I recently noticed a screw that holds my front fender on (the one on the side) which is pretty unique as far as i know, had fallen off. You can order any individual part from that site and it lets you see the schematics to find out what you need. Pretty helpful. you still have to pay shipping though.
May not help on this case (since its apparently a common bolt) but for future reference if you or anyone else who needs an OEM screw/bolt/grommet or anything else...
Also a marine store will probably have a stainless steel version which I think is what the tank bolt are...:D
I was going to go outside and take one out of my bike and check but it's too cold. A quick search tells me it is M6 x 15mm, slightly longer would also work but M6 is the thread (according to the service manual).
Thanks guys, I have yet to check out Ace hardware, I'll do that today. Lowes, Home Depot, Menards had the size in stock, or close to it, but weren't stainless.
If the bolt is gone the washer is probably gone as well, make sure you buy a nice big flat washer or it will damage the rubber mounting. I took one out of my bike today and the threaded bolt is about 15mm long, the washer is about 20mm diameter.
Loctite is probably a good idea as well. I just lost both of mine yesterday after failing to tighten them enough and not using any thread locker. I found this thread to try to figure out the bolt size.
