yea i took the cover off and the main gear is good, I thought it was maybe the ratchet gear or something but the entire spindle seams to be fine, # 2 spins as the motor doesn't turn over. so that's not the problem
look here's the spindle
Lowest price guarantee on parts / accessories for Honda Motorcycle, ATV, Watercraft, Scooter - OEM parts for less
Splitting the case, il have to get a a few gaskets that il have to replace, maybe even a head gasket ? and i think your right that its #18 thats stripped
you've been a great help Townsends thanks
No, problem.
I've never had an XR apart but their pretty similar to the old Yamaha YZ's, AT1's, DT's, Suzuki's, Kawasaki's I grew up on and split many a case..(second idler gear on a AT1 125, both kick starter gears on the same bike too, main crank lower bearing on a YZ 125 (fried in in a MX race many moones ago), replaced both crank cases on a Kawasaki big horn 350 single, 2 stroke (my friend thru the chain thru the left case), a Kawasaki 125 street bike, 2 stroke- bent shifter forks (she couldn't afford new forks so we bent them back, worked great!)...
Why your right there, that entire assembly should come out as a unit (pay attention to any shims on either end of the assembly). Just make sure, that main shaft and anything on that all the splines are fine and that the assembly is sitting in the case correctly.
I say this as splitting cases is
quite a bit more work to access that inner gear..
If all is fine with the outside kick starter assembly and you have to split cases, try to find a gasket set (head gasket, cylinder base gasket, side cover gaskets, etc).
The main center case usually DOESN'T USE a gasket but a specific case sealer.
I've used "Yamabond", I'm sure Honda has their own version (before squeezing out the tube, manipulate the sealer inside the tube to make sure its mixed very well, sometimes thin sealer will come out before the thicker, good sealer).
Make sure you DON'T scruff up the inner case surfaces (or any surfaces for that matter) and upon re-assembly, get the inner case surfaces
super clean (no gasket material, oil residue, etc). A light to medium coating of the Yamabond (or Honda equivilant) on both surfaces is all that's needed. Button it up the main cases as quickly as possible.
Ther transmission should sit in one side of the case (I don't know which for that engine),
probably the left case(with the main, clutch shaft sticking out). If it does, that kicker gear is right there and should pop off with the bushing.
Make sure, again, upon re-assembly, the transmision turns freely, the shifter forks, shafts they ride on, are all in place as well...
If there's any binding, somethings wrong, stop and re-check..
