I think the difference here is krid80 does not have an O2 sensor on his 2006. So the stock ECU on his bike is used to controlling fuel at idle and low load without one. On you 2 guys who added the PCv on O2-equipped bikes, if you unplugged the O2 per instructions, maybe the stock ECU is pulling fuel as a result (floating all the way to max (-) trim). So its running lean and rough. So if you add back in some fuel it smooths out. Remember the PCIII DID NOT SAY TO UNPLUG THE O2. The main reason IMO they say to unplug it with the PC-V is they want you to use the auto-tune to dial it in and that wont work if the stock ECU trims are fighting it.
I would be curious to see if you plugged in your PC-V **and** kept the O2 plugged in, if it would run ok with a 0-map.
Looking at the maps it just seems odd that the stock fuel map would be off by 20+ % in places...so they must be over-compensating for some "behavior" of the stock ECU.
Actually I did additional "testing" to try and isolate what is going on prior to returning the unit to Dynojet.
4 difference setups, all with the zero map in the PC-V, engine warm with 180 water temp, where I would slowly raise the rpm to 3000, hold 3K for a few seconds and then release the throttle and see the lowest RPM the engine dropped to.
Test 1 O2 connected, no PC-V, Idle RPM 1300, Lowest RPM ~ 1300,
Test 2 O2 disconnected, no PC-V, Idle RPM 1300, Lowest RPM ~ 1300,
Test 3 O2 disconnected ,PC-V / Zero map, Idle RPM 1300, Lowest RPM 0,
Test 4 O2 connected, PC-V / Zero map, Idle RPM 1300, Lowest RPM 0
The "Lowest RPM" is the lowest RPM observed when the throttle is released from 3000 RPM.
I then disconnected the PC-V, packed it and shipped it, returning the bike to O2 connected status.
Krid80 had an anomaly on his installation on the 06 also, idle speed dropped nearly to 50 % of what it was prior to installation. I think he said he just readjusted the idle speed by the screw adjuster. But no apparent reason for the idle change.
Thanks for the inputs, I really don't have any more ideas other than one I can't explore since the unit is in FEDEX care at the moment. What I was wondering about, was just connecting the PC-V to the injectors, and not the TPS, (only connect the 4 wire connector, and not the 6 wire connector) and see if the problem went away. That might help DJ isolate what is going on.
Oh well, time will tell.
Again, thanks
Andy
