This is another one of those areas, that I believe gets 'over thought'. If you are willing to consider the amount of surface area the clutch cable has that can evaporate stuff from, or collect stuff to intodurce to the interior of the cable sheathing.........
It's waaaayyyy less than 10% of the cable. How is it possible, for grunge to get into the middle? Doesn't it have to 'wick' in from either end? If you keep the ends of the cable properly lubricated and the linkages lubricated this
seems like a bulletproof setup.
The cable itself is not being subjected to anywhere near the stress that my Triumph put on the cable, or the H-Ds of the same period..... here my bike is, stored outside under a carport 365 days a year, and all the clutch system has ever seen for service is about a bi-annual shot of white lithium grease into the pivots, and onto the exposed ends of the cable when you extend it through the stroke. whatever can work it's way into the cable from there, does so.
It seems to me, that when you forcibly inject lubricant from an aerosol container into the cable, the same thinners and solvents that keep your new lube liquid enough to spray, are the very ones you are using to dissolve and remove the stuff the cable mfg applied when the cable was intially assembelled.
If there's sticky cr@p in the sheathing, there's no way enough force is being applied by that aerosol can to blow it all out. The cable itself is going to 'mask' a very large percentage of the inner surface of the sheathing.
I am of the opinion that you are more likely to drive
more crud into the interior of the sheathing, than you are to reduce the amount already there.
