You ever thought about this?
BranNwebster
The UNO Master
Webster Texas
That when you're at 12k rpm's in the time it takes you to say "one thousand and one" you had 400 little controlled explosions between your legs.
Spiffy!
Shouldn't it be 800?
12,000 rpm * 4 cylinders = 48,000 explosions per minute
48k/min * 1min/60sec = 800
Or perhaps I completley misunderstand how an internal combustion engine works, which is entirely possible.
Each cylinder only explodes (ignites) every other rotation of the crank shaft. The in-between motion is the exhaust phase of the cycle.
interesting thought....good to see I'm not the only guy that just had to the
math after reading it...:D
and rsw81 is correct, on a 4 cycle engine, not every down stroke is a power
stroke, every other one is, with the one in between being an intake stroke
The original post was right:
48k/min * 1min/60sec = 800 then / 2 = 400
You need to divide this by 2, it is a 4 stroke, only 1 fire every 2 rpm. 800 would be right if it was a 2 stroke...
Andrew
Machines amaze me. I used to walk right by a 600 Megawatt generator every morning on my way to the shop at the power plant I worked at. The generator rotor weighed 55 tons and that thing rotated 60 times every second. The rotor was coupled to a steam turbine that had multiple blade sections the largest being about 12 feet across. I can't even guess how much it weighed. It was being pushed by 1500 psi steam though. Yep I love my work.
