C++ Programming homework help
scoobydrvr
Central Ok.
Lame, I know, but I'm taking a summer class and i've got an assignment that has me stumped.
I've got to overload the += and -= operator so that I can increase the value of a variable within an object by a value. For example:
SavingsAccount saver1;
saver1 += 234;
This needs to increment a data member called savingBalance belonging to the class SavingsAccount.
Wikipedia and all other sources I've tried have failed me. I'm hoping there are some professionals here that can offer me a hand... please?
thanks... believe me, the only reason i'm taking it is because I have to. It doesn't help that the one guy I know in the class has his phone off and my textbook is useless...
A seasoned programmer/nerd here, this will be a good start for you to read:
C++ Operator Overloading Guidelines
Basically you'll want a function within your object similar to the following:
MyClass & MyClass:: operator+=(int addedValue) { // no space between :: and operator, had to do it to avoid smiley
// Do the member variable addition work here.
MyClass.yourVariable = MyClass.yourVariable + addedValue;
// or if you can "see" the variable globally
yourVariable = yourVariable + addedValue;
return *this;
Not gonna do the homework for you, but hope that helps!
-Dave
That helps immensely, but now I'm getting a syntax error "missing ' ; ' before ' . ' " on the line
SavingsAccount.savingBalance = SavingsAccount.savingBalace + addedValue;
It's producing two of those errors for this one line and I'm totally at a loss for this one...
fixed it.
Header:
public:
SavingsAccount& operator +=(float newAdd)
.cpp:
SavingsAccount& SavingsAccount:: operator +=(newAdd)
savingBalance = savingBalance + newAdd;
return *this;
thanks dave for your help getting me started!
fixed it.
Header:
public:
.cpp:
return *this;
I see a typo on the RHS.
If its an instance member variable, then you shouldn't be using the class name:
Code:
savingsBalance = savingsBalance + addedValue;
or
Code:
this.savingsBalance = this.savingsBalance + addedValue;
However, if the savingBalance variable is a static class member variable, then you have the appropriate syntax:
Code:
SavingsAccount.savingsBalance = SavingsAccount.savingsBalance + addedValue;
In ironyx's example above, you were supposed to choose one or the other. Instance variables (and objects) can be created multiple times in a program (say like a database or web site). Static class member variables can only be created once and are only accessed via the class (SavingsAccount.) (if the program can only access savings account).
