dont let all that confuse you, just remember
Suck
Squeeze
Bang
Blow.
Suck
Squeeze
Bang
Blow.
Bring back 2-Stroke engines I say. :ban:
True, there's hardly any 2 strokes out there anymore all you hear is Brrrrap Brrrrap Brrrrap. Hardly ever Ring dingding ding dingding ringdingding. Hahaha!To be completely honest, almost all ORV's are 4-strokes these days, due to EPA regulations and all. Even the racers have gone 4-stroke. Snowmobiles are also headed in the 4-stroke direction. 2-strokes are all but dead.
Suck
Squeeze
Bang
Blow.
Because different people wrote the specs and they both put what they think was important.![]()
You know, I'm really impressed. A guy who'd been flaming away out of his depth a couple of days ago posts a pretty naive question and pretty much gets nothing but straight, well-considered answers.
Y'alls good people. :thumbup:
Most inline 4 stroke 4 cylinder engines have a similar firing order. The fz6(r) engines have a "flat" crankshaft or, each throw is offset 180 degrees from each other. The outer pistons(1 and 4) and inner pistons(2 and 3) move up and down as a set. The firing order is usually 1-3-4-2, each 180 degrees from each other. The New R1 has a cross plane crankshaft, with 270, 180, 90, 180 degree firing interval (not firing order). This puts the each throw 90 degrees from each other, and helps smooth out the power delivery. The firing order is still the same, you just have different amounts of crankshaft rotation between each power stroke.
A standard flat crank inline four also has inherent balance issues. Due to the inline nature and 180 degree offsets, a natural imbalance occurs. It is called a second order imbalance or vibration, since it occurs at a rate of twice the crankshaft speed. This is why on larger engines, a balance shaft (a Mitsubishi invention) is used to cancel those vibrations. The new R1 engines have a first order imbalance, one that occurs at crankshaft speed, so Yamaha uses a primary coupling balancer to quell those vibrations.
V6 engines and bigger (number of cylinders, not displacement) have more leeway in firing order due to more power strokes each crankshaft revolution. The angle of the V also determines the firing order and dictates what type of crankshaft offset is used.
I was surprised that most inline motorcycle engines use the 180 degree offsets. 90 degree intervals seem more balanced. I guess it's more effort/cost to manage things individually (firing and injection) than for two sets of two.
Not easy to describe is correct. But you sir have done it beautifully!
I must spread rep around before giving it to wolfc again.......:don'tknow:
