Do you blip the throttle?
Yeah I do that a lot. It's pretty easy to get the hang of it and lets you take more advantage of engine braking. Feels kinda cool when you really time it right and you don't even feel a lurch.
Tim
Every time. Getting better at braking and blipping, but under tense situations it becomes difficult.
Yes all the time, the throttle is quite jerky from nothing, so blipping the throttle and using the clutch evens things out a lot.
I do it all the time. Just need to stop doing it automatically when the RPM's are really low, because then I always over rev it accidentally.
Throttle blip AKA rev matching. Revving the engine so that upon a downshift the engine speed matches what is required from selecting a lower gear.
It eliminates the forward lurch from dropping to a lower gear.
Also can be combined with braking. While braking, the throttle is twisted to bring engine speed up, then clutch is released. You can see why braking and blipping is hard. Braking and throttle is controlled with the same hand.
In a car it's called heel-toe shifting. As you brake with the toes, and blip the throttle with the heel of the same foot.
Ok I'm a noob, what on earth is blipping? LOL!
LOL...its rev matching while you down shift thru gears. It takes a lot of practice to master.
The idea of blipping the throttle between downshifts can be intimidating for the uninitiated, but with a little practice, the technique can soon become second nature. First, make sure that your levers are adjusted so that they are comfortably in reach of your fingers when sitting in a normal riding position, and that your throttle is adjusted for minimal play in the cable. Then practice simultaneously pulling and releasing the clutch quickly when you blip the throttle.
In order to avoid upsetting the bike, the engine rpm must be matched to road speed when the clutch is fully disengaged, otherwise the rear tire will momentarily "chatter" and upset the bike as the engine is forced to match road speed involuntarily. This means that the rider must "blip" the throttle to raise the engine rpm during downshifts.
Hope this helps.
Hope this helps.
Makes no sense to me. LOL! We were just showed in BRC to just pull the clutch in and break to a complete stop then downshift all the way to first.
