Scorpion Exhaust Instuctions
Mississippi
Southaven, MS
Scorpion Exhaust Instructions
I have just come into possession of the oval style scorpion slip-on exhaust in the stainless steel, but the person that I bought them from did not have the instructions.
Does anyone have a copy of the instructions that they can scan, copy, fax....anything?
fz6joker
Damn Hooligan
Premium Member
Kentucky
You could probably go to Scorpion's home webpage and get instructions there. I'm at work or I would search em out.
Mississippi
Southaven, MS
I tried, but I was not able to find them. I even contacted someone their, and this was their response:
Hi Robert
I have tried to forward the instruction but it will not send due the size of the file.
So, if someone has them, I sure would appreciate getting a copy. Thanks.
Mississippi
Southaven, MS
I got the exhaust Friday night, and could not wait to put it on, so after the kids went to bed, I went to the garage. About 1 1/2 hours later, all done.
Gilo-FZ6
Riding the Big Honda
Premium Member
Cardiff,SoWal
good work..those are the worlds shineyest set of zorsts ive ever seen..they need to come with a warning :)
Mississippi
Southaven, MS
did you have any problems with the clamps striping, and did you check for leaks?
No I did not have any issues with the clamps. I cannot hear a leak, but on the right side of the bike (brake side) I can feel a little air from where the can attaches to the "Y" pipe. I think I am going to go back and slide that clamp up a bit. When I was tightening it, i guess it slipped down a little, and does not cover the cuts in the pipe for expansion.
SANGER_A2
Southampton
Damn those things look good! Nice job. VERY shiny! :D I love the bands that you use to mount them. They're nicer than the ones you get on the new ones.
Did your pipes all fit together nicely? My Y-pipe doesn't fit perfectly onto the stock cat pipe jobbie.
Mississippi
Southaven, MS
Thanks Sanger:thumbup:, those bands are the one's that came with them. Do you have the new style?
As far as the pipes fitting together, no not really. They fit ok, but I will still need to do some tweaking. My Y-pipe, fit on the stock cat pipe just fine. I figured that is where I would have my problems, but that was not an issue at all. However, I have not got them exactlly right yet I do not think, so the y-pipe could be my problem after all.
SANGER_A2
Southampton
Yeah I've got the newer style. There's details of them here. I found that the Scorpion Y-pipe fitted fine to the scorpion exhausts but not too great to the Yamaha cat pipe. I've bought some stuff I mention on the thread to use to fix that next time I take them off.
Mississippi
Southaven, MS
What does the Holts Firegum do? Is it like a gasket sealer or JB weld or something? If you put the Firegum on, will you be able to take the exhaust off if you ever wanted to? I can feel some air at the joint of the right or brake side and at the cat connection of the Y-pipe. I thought about just moving the clamps up to the start of the flairing of the Y-pipe and can to try to stop the leak.
