aid-90
hi i was wondering what the filter is behind the down pipes at the front of the engine? its not the oil filter as that is located on the bottom left side of the engine am i correct??
i was wondering about the cylindrical shaped object at the front of the engine with the nut at the front of it
That's the oil cooler
Are you referring to the water pump? That is in the front of the block behind the header, right?
