fz610
Hi. Recently I got my rear tire changed and after that I was hearing a squeaking noise from the rear wheel . The noise was more pronounced when I was engine braking and when I was doing low speed left turns. Today I removed the rear caliper and I found the problem. It seems that the disk is not centered in the slot of the caliper carrier. It it slightly touching on one side and on the other side there is a big gap. I attached some pictures to be more clear. I also took out the wheel and everything seems fine, so I do not understand, what can be the root cause of this misalignment?
Model: FZ6 S2 ABS 2010
