Have2BeFree
It's My Bike!
I'm not sure if it's the tire or the rider but I'll try to give a brief explanation and would appreciate any input from the forum.
I recently put new tires on the bike. I had 13,500 miles on the front and 14,200 miles on the rear of the old tires which were Dunlop RoadSmarts. I replaced them with Michelin Pilot Road 2 tires. I couldn't afford to do both at the same time so replaced the rear first and then the front - about two weeks and 500 miles apart.
I had no problem with the rear tire. However the bike just doesn't seem to feel the same or handle the same with the new front tire. I just brought it back to the dealer to have the balance checked (there was no weight on it) and the mechanic said that he did add a little weight but it was so small that I really wouldn't have noticed it.
The torque is fine - my friend checked the specs twice after he put the wheel back on. The air pressure is good as well. I now have over 500 miles on the tire.
Not to sound like a newbie or worse yet, a girl, but it just doesn't feel right. At slow speeds cornering seems unsteady and gives you that "i'm going to fall over feeling". At higher speeds going straight it just doesn't feel like it's rotating correctly. There is no shaking or anything and it does seem to stick ok at higher speeds in the turns though I haven't tried anything over 60 mph cause I'm feeling a little unsteady with it.
Anyone have any ideas or advice? Is it just the difference in the tires?
