yamafz6db
Does that more expensive air filter give your bike any better performance? Thanks Dave
I'm thinking about replacing my air filter early since there is a lot of sand and dust here in Vegas. Is this K&N filter available at any motorcycle shop, and what size is the filter and how much should it cost? I really haven't looked anything up as far as air filters, and this post just conveniently appeared.
Pick up a K&N Cleaning kit at the same time and clean it when you change your oil.
i have always noticed the sound change in my cars, but haven't put one on my bike yet.
Only thing with the K&N's is to make sure you oil them and clean them per the instructions. If not, you might as well have nothing in there.
And I remember seeing an article or two before comparing a K&N to a typical paper filter and the results weren't quite as expected. I'll have to see if I can dig it up.
This is one I was thinking about:
Air Filtration Test
Really sums up more about the filtration abilitiy, but also uses a pressure differntial test to determine air flow. Interesting read if you've got a while.
