Need Help ODO flickering ER 3 code, on and off. Not working anymore when during riding.
FZ6-2006
Finland
Hello FZ6 fans.
I have a issue with my bike and I am curious if happened to someone else before.
Short description, is that I had my motorbike in "warm" garage during the winter without battery. This year, after I have installed a new battery (same model as before, YUASA 10.5 Ah, 12v), when I start the motor, it "flickers" ER 3, with max temp, for a brief second, then recovers, then appear again.
After the motor its getting warmer, this flickering disappear, but when I start to ride with more than 30 km/h ish, temp meter becomes automatically max, and the speed shows either max or zero km/h. Slower the speed it recovers, but this code flickers again, sometimes.
It this a short circuit somewhere? Or is the ODO toasted? What are you thoughts?
I have cleaned the connectors under the ODO, cleaned the connectors of battery, and around battery ( what I have touched when changed the battery), and also cleaned all breakers and ECU connector. No luck, problem still persist.
I have attached a video with a post that I wrote on Reddit also, for a better understanding how it looks like.
No problems before the winter.
Also apologize beforehand if my phrasing it is a little bit weird, English its my third language :). For any questions, please let me know, I will try to explain better my case.
Thank you all.
Welcome to our great forum!
It might be good to check the connection at the ECU module. There is a data line between the ECU and the instrument cluster. The ER 3 is the code for a problem with data transmission from the ECU and the Instrument cluster.
Thank you for your fast answer. I will check ECU connection and clean it some more! Do you know what colour it is the data cable from ECU to cluster? Shall I open all black tape and follow it fully?
The data line should be a yellow with blue tracer wire. The plug at the ECU may have a problem. Sometimes salt contamination can cause cross talk between pins and that could be the problem. I would also not rule out the possibility a rodent has been present and caused damage to wiring. Keep an eye out for signs of rodent activity.
Removed ECU and cleaned inside.
The connector had a very "cooked" rubber lining, that fall off half of it. Dont know if it was damaged before or it broke now when I have disconnected the ECU for cleaning. Removed the lining completely to be able to connect it back. (Pic3)
Cleaned all the connections with yellow/blue lining.
The error still appear and disappear.
My garage its inside the house (part of the house?), I have checked for rotten sign activity, but it is highly unlikely as I go inside quite often and clean it quite regularly all year around.
It is possible for the ECU or ODO to go bad? Or its more likely for the connector/cables to fail?
