I hope you're right, and it doesn't hurt anything. Like I said, I'll trust the guys that engineered it.
Cheers,
Rick
I've owned numerous Yamaha motorcycles since 1970 and consider myself a Yamaha guy (I own a Yamaha 4 stroke outborad as well). I trust the engineers very much as well or I wouldn't own a Yamaha(two actually).
However, if you've done any serious wrenching, you'll know there are short cuts to certain procedures, etc. IE, when sync'ing your TB's, Yamaha DOES NOT mention checking the sync,
besides at idle, at 4,000 RPM's.
I had an annoying vibration thru the bars and seat, which after playing with the sync and re-adjusting at 4,000 RPMs (and keeping within spec's at idle) got rid of 90% of the vibration.. Yamaha allows 10mm between the TB's, mine are within 3mm. The dealership will, on most occassions, tell you its normal (the vibration), sync within 10mm and send you on your way...
I suspect with the very short clutch engaugement zone, and being a 600cc bike (generally a starter bike), the idle is spec'ed higher some so new folks can get rolling without stalling.. My 04 FJR (very similar engine) idle was spec'ed to idle at 1,000 to 1,100 RPM.
I can also mention how I had a problem with my FJR when it was fairly new and started running crappy (still under warranty). After the re-called TPS was replaced, it still didn't run right. A $125 throttle sync (I didn't own a sync tool at the time) didn't help (that was done incorrectly BTW by the mechanic-he adjusted the buterflys, not the air screws-its NOTED IN THE MANUAL
NOT TO TOUCH THE BUTTERFLYS.)
The dealership tried hard, I'll give them that, and was on the phone with Yamaha headquarters in Ca
numerous times trying to fix the problem but could not figure it out.
I did have one mechanic at that dealership come out and tell me the misfire/bog was normal.. Getting really pissed at this time, I told him to please leave as he doesn't know what he's talking about.
Keep in mind, Yamaha tech's in Ca,
could not figure out the problem. After approx 6 hours, I rode home, bike still not right.
Checking the internet (FJR forum), I was able to find the problem on the internet. A main harness plug, under the gas tank, likes to collect moisture(rain, washing, etc) and corrode.
Mine was nice and green..
Once cleaned and di-lectric grease installed, it was fixed and ran great after that...BTW, the Yamaha manual DOES NOT MENTION PUTTING di-lectric grease in the connector (nor did Yamaha tech guys mention checking this plug, hmmm)...
It was a common problem, posted and found on the internet (by fellow FJR owners), NOT known at the dealership or at Yamaha headquarters apparently... It was designed this way, by Yamaha ENGINEERS, IMHO, DUH!!!
So, in my experiance, real world riding/wear/tear and the internet, Yamaha (or any other manufacturer) does NOT know everything, especially after the bikes been on the road for sometime in real world conditions...
That's why they have re-calls as well....
Also, as stated earlier, the lower idle, for my bike, eliminated the vibration in the mirrors, I prefer the sound of it, and
most importantly, dropping into first gear from neutral is not nearly as big a clunk as the transmission is turning a bit slower. Holding in the clutch lever for a couple of seconds also helps slow the transmission spinning as well...
Set it at 1350, don't use di-lectric grease on on connectors exposed to moisture (as Yamaha engineers don't say to), etc... Just some of my experiance and of course, my opinion.....
