recko
dennis
Can these 2 items be used together? Anyone tried before? :Flash:
Regarding the light kit, if you wanted to use the Givi quick-connect method, the light kit comes with a piece you snap into the mounting plate. It will fit either the M5 or the E250 plate, there's a circle you knock out or drill out in the plate and the connector snaps in.
Thanks for your fast answer!
About the part that it is quoted, is there a picture or a guide? Is it vunerable to rain (when the case is not mounted)?
Does someone have it? Or can provide a link with more information about it?(does it have also the flash indicators or only brakelight? etc.)
