ChevyFazer
Redneck MacGyver
Also, for those experiancing improper brake wear, Yamaha does recommend replacing brake seals every TWO YEARS (page 4-40, 06 manual).
I do know from experiance from my FJR, the seals may look good, not leak but do indeed apparently harden and stick on the pistons. A good cleaning and new seals make a BIG DIFFERENCE. My FJR, I didn't rebuild them until probably 5 years old.
Something I also found to work very well and is made for brake seals/pistons is Permatex brake grease: Amazon.com: Permatex 24110 Ultra Disc Brake Caliper Lube, 8 oz Brush-Top Bottle: Automotive
Use a minimal amount, definitly eases piston movement vs brake fluid only as a lubricant...
Is there any benefit to using that over good ole fashion anti seize?
