Sudden onset of a dreadful rattling noise
Remi
Ireland
If you spun it and nothing locked up/hit, you should be ok..
The engine turns / runs clockwise (looking from the right/starboard side) and the chain is taught from the crank, to the ex cam, then the intake cam. Slop is at the rear where the CCT takes that up.
ALL marks should line up or be super close(chain stretch would move marks off some). A full tooth off would be VERY noticeable with your marks..
Ok and for the record, I didn't turn it counter clockwise, I was just curious haha
Gary in NJ
Amoungst the Twisty Roads
For the sake of good order, I’d do a leak-down compression test on all four cylinders. On a cold engine you are looking for an 80% hold on your reference pressure.
Remi
Ireland
Yes, no harm to do that, I dont have the tool for it though so I'll order one tomorrow.
Gary in NJ
The kit that they sell at Harbor Freight is fine for home mechanics. I’ve had mine for 10 years and it works. I usually use a reference pressure of 80 psi.
