Is there any other way to do it? LOL I got all that in stock Mate... Thanks. It end up to be very close to whatever the timing mark were lining up. So I started there... any educated guess is a good guess... to get a base line. So far it look very good. The mid range got a good kick and still breath very good all the way to the rev limiter. I might be able to retard the Intake a bit to get a bit more of that top end rush... but I need to be careful. I'm short 2K rmp compare to you. So whatever I do it will feel a bit more flat torque compare to a FZ6.
I'm still working on the map to smooth thing up before I do a base line run on the dyno. Getting close. If it all look good I'll get it tune on the dyno, the right way!
So is the intake and exhaust stock? Any chance the FZ6 injectors and T/Bs bolt up?
Also, keep an eye open for an ignition advance module, a few degrees added (electronically) could be be sweet spot on the top end. Not sure if you played in that realm much but it makes huge difference. . .
