pulverizer
I am not sure if anyone else has tried this mod for the stock windscreen, but the idea came to me the other day. I had switched back to my stock windscreen for the summer, because the Cal-Sci I had was just too hot when it was over 80 outside.
So, I have seen mods where people cut out parts of the stock windscreen to try to reduce the turbulence, but I did not want to cut mine, so I thought of another way to go. Instead of cutting, why not just lift the windscreen up a little to let air in on the sides of the windscreen.
To do this mod, I just got longer screws along with some plastic and rubber washers to act as spacers to keep the windscreen about 1/2" to 3/4" above where it originally sat on the fairing. This leaves a gap all along both sides, possibly leading to less turbulence, since it might help to equalize the pressure on both sides of the windscreen.
Results: Take a look at the pictures...I think it looks good because it keeps the look of the stock screen, and you cannot notice anything is different unless you look up close. I did a quick test ride on the highway today, and I think it improved things a bit. It seemed a bit quieter overall, and there seemed to be a little less turbulence knocking me around.
If someone else wants to try this, please let me know if you think it is an actual improvement, or if this was all in my head!
The only negatives that I encountered were that since you are lifting the windscreen a bit off of the original mounting holes, you do end up putting a little more stress on the windscreen (since it ends up flattened out slightly) and on the mounting holes. The mounting holes are very flexible, so it seems like they might be ok. The end result was very secure, and it did not seem to move anywhere on my test ride.
Let me know what you think!
