Poor design OEM tools kit
hazy
Singapore
Well,i guess it is time for me to adjust my chain.As this is the first time doing so,i uses the 32mm Yamaha tool to loosen the axle nut and made adjust as per owner manual.After completed the process,I find my swingarm was full of scratches caused by using the stupid OEM 32mm wrench.:(
Lesson learned,always get a proper 32mm socket ready before doing any chain adjustment.
blu04
Richland, WA
I just did the same procedure and had no problems using the tools in the pouch, they might not be the greatest tools but they do get the job done.
fazer.rider
Toronto, Canada
wow you must have super human strength to get leverage using that little wrench. then you have to tighten it to about 100 ft lbs. how did you do it?
Sawblade
Hopped up on Mountain Dew
Japan
Easy, you slide the metal sleeve looking thing over the end of the 32mm wrench. That's what it's there for. :D
barijack
Union City, Tennessee
Yeah like the other dude said, there is a hollow tube that fits over the 32 wrench that makes it twice as long and plenty easy to loosen and tighten.
as for scratching anything, just be careful. the axle wrench has plenty of an angle to it to stay away from the swing arm
SANGER_A2
Southampton
Yeah they suck. First time I used mine, it snapped the allen key when I was removing the seat side pods! :( Yamaha seem to torque all the bolts down a huge amount. I'm slowly replacing the allen bolts on the bike that I use a lot with proper bolts.
